Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the drill isn't working effectively it might be because of the gears, so this guide will show a step by step process on how to access the gear and to change necessary components.
Выберете то, что вам нужно
Gently grab both sides of the drill casing, and separate both sides from each other.
After following the prerequisite guide you will be able to access the interior components of the drill.
To be able to get into the gears you will need to separate the motor from the rest.
And then you will be able to access the gears which is located between the motor and the chuck.
Twist the gauge to change between the gear.
If you don't hear a clicking sound then check the gears.
Check if any gear is chipped or broken in any way.
If it is then you will need to change the broken gear.
