Black and Decker LDX 120C Light Replacement
Выберете то, что вам нужно
  1. Black and Decker LDX 120C Light  Replacement, Outer Case: шаг 1, изображение 1 из 1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Light  Replacement: шаг 2, изображение 1 из 1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Light  Replacement: шаг 3, изображение 1 из 1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Light  Replacement: шаг 4, изображение 1 из 1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Light  Replacement: шаг 5, изображение 1 из 1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Light  Replacement: шаг 6, изображение 1 из 1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Light  Replacement: шаг 7, изображение 1 из 1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Light  Replacement, Light: шаг 8, изображение 1 из 1
    • After following the prerequisite guide the drill is now open and you can see all the components of the drill.
  9. Black and Decker LDX 120C Light  Replacement: шаг 9, изображение 1 из 1
    • First separate the top part of the drill, which includes the motor and the chuck, from the rest of the components.
    • Remove carefully so that wire connection is not damaged throughout this process.
  10. Black and Decker LDX 120C Light  Replacement: шаг 10, изображение 1 из 1
    • Then separate the other component which includes the trigger, light, and the connection to the battery.
    • Do this carefully so that no wire connection or any component gets damaged.
  11. Black and Decker LDX 120C Light  Replacement: шаг 11, изображение 1 из 1
    • First check if the connection to the light is not intact.
    • If the wiring is lose simply reconnect the wire.
    • Then check if the light bulb is not damaged in any way.
    • If the light bulb is broken or simply just burnt; simply replace the light bulb.
  12. Black and Decker LDX 120C Light  Replacement: шаг 12, изображение 1 из 1
    • Grab the connection of the light bulb.
  13. Black and Decker LDX 120C Light  Replacement: шаг 13, изображение 1 из 1
    • Using pliers cut the two connecting wires from the mother chip.
    • To prevent potential damage to the component, try desoldering the wires. Learn more about soldering here.
Заключение
jeffrey zakka
Участник с: 02/09/16
735 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 11-5, Cheng Spring 2016 Участник USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 40
За всё время: 17,392
