Введение
To be able to get into the components inside the drill we will have to open the drill by undoing thirteen total screws, and this guide will illustrate this.
Запчасти
Детали не указаны.
  1. For this guide we will need to use a 1.0 mm phillips #1 screw.
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Remove the four screws on the back top side of the drill.
    • Remove the four screws on the back top side of the drill.
  3. Remove the four screws that connect the chuck to the drill.
    • Remove the four screws that connect the chuck to the drill.
  4. Remove the five  screws on the front side of the drill.
    • Remove the five screws on the front side of the drill.
  5. Gently grab both sides of the drill casing, and separate both sides from each other.
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. At this point you should be able to separate both as illustrated.
    • At this point you should be able to separate both as illustrated.
  7. Now all the components of the drill are visible and can be accessed.
    • Now all the components of the drill are visible and can be accessed.
Заключение
jeffrey zakka
Участник с: 09.02.2016
678 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 11-5, Cheng Spring 2016 Участник USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 27
