Выберете то, что вам нужно
To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
Turn the vacuum around until you see the company logo. Once we are there remove the two screws on the vacuum.
Once all screws are removed the casing of the vacuum can be removed.
Remove the L-shaped plastic hook.
Once the L shaped hook has been removed the motor will easily fall out of place.
Disconnect any wires or components attached to the motor by gently unplugging them. Remove the motor by unscrewing or unclipping it from the casing
This will then allow for you to replace the motor.
To get to the charging port you will need the plastic opening tool.
Remove the three screws on the handle of the vacuum.
Remove the plastic covering to the port.
Remove the wires to replace the charging port.
