Введение
This will guide you through the process of removing/replacing the Actuator Fwd/Rev switch on the Black and Decker PS-1800.
Выберете то, что вам нужно
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Start separating the outer shell into two parts.
You will find the Fwd/Rev actuator on the right side of the drill, underneath the motor.
Carefully remove the actuator from the drill.
Replace the new actuator by inserting it the same way you took it out.
2 участников успешно повторили данное руководство.
