Black and Decker PVH1810 Hand Vac Battery Replacement
Выберете то, что вам нужно
  1. Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: шаг 1, изображение 1 из 2 Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: шаг 1, изображение 2 из 2
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 2, изображение 1 из 2 Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 2, изображение 2 из 2
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: шаг 3, изображение 1 из 2 Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: шаг 3, изображение 2 из 2
    • Remove the three screws.
  4. Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 4, изображение 1 из 2 Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 4, изображение 2 из 2
    • Flip the hand vac over and remove two screws.
  5. Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 5, изображение 1 из 3 Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 5, изображение 2 из 3 Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 5, изображение 3 из 3
    • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
    • This will then allow for you to replace the motor.
  6. Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: шаг 7, изображение 1 из 3 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: шаг 7, изображение 2 из 3 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: шаг 7, изображение 3 из 3
    • Remove the three screws highlighted with red circles.
  7. Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 8, изображение 1 из 2 Black and Decker PVH1810 Hand Vac Battery Replacement: шаг 8, изображение 2 из 2
    • Remove the battery by pulling it out of the slot it sits in.
Заключение
7 участников успешно повторили данное руководство.
Nicholas marsoobian
Участник с: 09/24/18
480 Репутация
Автор 3 руководств
12 Комментариев
Where can I get a replacement battery?
Lisa - Ответить
Anyone? Good place to order a replacement?
Brad - Ответить
“Remove the battery” sounds pretty simple, but my pivot vac seems to be “hard-connected” to the battery terminal, and I haven’t a clue where to go from here (though the trash heap—and recycling center—are strong candidates). Mine is an older model (2012) and perhaps that explains why these otherwise excellent instructions lead me to a dead-end.
Jim 4/14/21
James Bonner - Ответить
Agree. I dissembled down to this last photo, but the battery won’t budge.
MJ Waz - Ответить
the gray handle on one side pops open if you pry at it and there are screws underneath.
Matt Whats -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 42
За последние 30 дней: 153
За всё время: 6,789
