Введение
If the LED light in the drill no longer turns on, you can use this guide to easily replace it with a new one.
Выберете то, что вам нужно
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
The black plastic piece is the housing. The light is placed inside this black plastic housing.
Pull the black plastic piece up out of the slot in the drill body that it fits into.
The light itself can be easily removed from the black plastic piece by simply pulling it out.
Take your new LED and slide it back into the plastic housing in the same orientation as the old LED.
2 человек успешно провели ремонт по этому руководству.
