Black and Decker Pivot Plus PD600 Motor Replacement
Выберете то, что вам нужно
  1. Black and Decker Pivot Plus PD600 Motor Replacement, Drill: шаг 1, изображение 1 из 3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: шаг 1, изображение 2 из 3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: шаг 1, изображение 3 из 3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Motor Replacement: шаг 2, изображение 1 из 1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Motor Replacement, Motor: шаг 3, изображение 1 из 1
    • After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
    • However, do not pull too hard because the motor is attached to other components of the drill by wires.
  4. Black and Decker Pivot Plus PD600 Motor Replacement: шаг 4, изображение 1 из 2 Black and Decker Pivot Plus PD600 Motor Replacement: шаг 4, изображение 2 из 2
    • After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
    • Mark or color code the black and red wires so you can return them to the correct position.
  5. Black and Decker Pivot Plus PD600 Motor Replacement: шаг 5, изображение 1 из 1
    • Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
Заключение
4 участников успешно повторили данное руководство.
Jonathon Centofranchi
Участник с: 04/19/13
307 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 4-15, Maness Spring 2013 Участник Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 членов
Автор 6 руководств
Один комментарий
If my motor try to turn is there anything I can do to fix-it? :)
Kenny Ray Carder - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,303
