Введение
If the motor of the drill stops working, this guide will show you how to remove the motor of the black and decker Pivot Plus PD600 whether for repair, or for other use.
Выберете то, что вам нужно
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
4 участников успешно повторили данное руководство.
Один комментарий
If my motor try to turn is there anything I can do to fix-it? :)
