Введение
This guide will walk you through the process of removing the pivot button on the Black and Decker Pivot Plus PD600.
The pivot button may need to be removed and checked for contaminants if problems such as jamming of the button occur.
No special skills or tools are required for this disassembly.
Выберете то, что вам нужно
Locate the pivot button screw labeled with a lock symbol.
Remove the screw with a Phillips #1 screwdriver.
Set the screw to the side.
Remove both sides of the button from the screwdriver.
