Введение
This guide is used to replace your toast oven door completely. If your handle is broken or melted, you will have to replace the door fully. You will have to remove the top cover, control knobs, and the door spring in order to remove the door. There are five steps in this guide to help you get your door replaced.
Выберете то, что вам нужно
Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
On the TO1313SB, a Security Torx T15 driver is required — the screws have a center pin that prevents use of a regular T15 driver.
Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
With the needle nose pliers, grasp the hook of the rear spring as close as you can to the coils. Stretch the spring back and, with a twisting motion, pull the hook out of its catch.
Using two metal spudgers, pry the top control knob directly outward.
Remove the two #2 Phillips Head x 5.5mm screws holding the timer controls to the face.
On the left side, use a metal spudger to push the hinge pin in as far as you can.
Инструмент, используемый на этом этапе:Tweezers$4.99
On the right side, pull the now extruded hinge pin out about 1/4 of an inch.
On the left side, push out the spring attachment while pulling on the door in an upward, outward, location
To remove the door, slightly pull the bottom left corner away from the face and slide the entire door to the left.
Один комментарий
I have the Black and Decker TROS1500 SpaceMaker Toaster Oven and the door handle fell off. Although my model is somewhat different, these images gave me the confidence to disassemble the unit and remove the door to work on the handle. I thought a rivet had broken, but it turned out that the handle attaches with screws and the screws had just come loose. I could have fixed that without disassembly, but I may not have started if I hadn’t seen this page. Kudos to you and IFIXIT!
I was not able to find any repair images or video on Google or YouTube. The SpaceMaker line is down to one model with mediocre reviews. I’m glad I was able to repair mine and save $130.
