Введение
Learn how to manipulate your Black and Decker Toast R Oven in order to clean it, to replace its door-spring mechanism, and/or to replace its damaged door.
Выберете то, что вам нужно
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Hi I am doing my own repairs on a black and decker toaster oven and need some help. identifying that part under the oven where the power cord enters the enclosure its actually a disconnect switch to disconnect the power when the door is opened.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Remove the four Phillips #4 1 cm screws from the back of the unit.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
Remove the spring from the door mechanism by pulling it off.
Replace the old spring with a new spring.
Separate the door mechanism from the door by tilting the door to relieve the mechanism.
4 участников успешно повторили данное руководство.
2 Комментариев
sale humo al momento de prender el horno
