Введение
If the toaster door does not stay shut, heat will escape and the toaster will not work properly. This problem can be solved by simply replacing the door spring mechanism.
Выберете то, что вам нужно
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
Remove the spring from the door mechanism by pulling it off.
Replace the old spring with a new spring.
2 участников успешно повторили данное руководство.
2 Комментариев
Great guide! Very clearly-written and accompanying photos captured the process effectively.
