Введение
This page gives instructions for disassembling the Black and Decker WP900 6-Inch Orbital Waxer and Polisher to where the external casing can be removed from all internal workings.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
Be sure to keep track of where each screw was placed in the device for later reassembly.
Remove the back panel of the external casing, leaving all internal components resting in the front panel.
Remove the black handle from the main external casing.
Using the Phillips #1 screwdriver, remove the two 22mm screws.
Using the Flathead 3/32" screwdriver, remove two 22mm screws.
Firmly grasping the motor dislodge the internal components from the frontal external casing.
Once the motor has been removed, the external casing can now be replaced.
Один комментарий
Hello, this is Adam Kinnett from Group 7. You have done an excellent job on your photos as well as the descriptions and formatting.
**One of your Wiki pages on the search says "Back and Decker".
