Введение
This page gives instructions for disassembling the Black and Decker WP900 6-Inch Orbital Waxer and Polisher to the point where the motor can be fully removed and replaced.
Выберете то, что вам нужно
Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
Be sure to keep track of where each screw was placed in the device for later reassembly.
Remove the back panel of the external casing, leaving all internal components resting in the front panel.
Remove the black handle from the main external casing.
Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
Using the Flathead 3/32" screwdriver, remove two 22mm screws.
Firmly grasping the motor, dislodge the internal components from the frontal external casing.
Using a Phillips #1 screwdriver, remove the two 22mm screws securing the brush assembly to the motor.
To fully remove the brush assembly from the motor, push the brushes (enclosed in the gold ribbing) outward and pull up.
Еще один человек закончил это руководство.
Один комментарий
Very straightforward tutotial. We are writing review of this product here https://www.helpful.reviews/en/product/4.... However we have not found many cases among owners of this product that they would need to repair motor by its replacement.
