Введение
This page gives instructions for disassembling the Black and Decker WP900 6-Inch Orbital Waxer and Polisher to the point where the on/off switch can be fully removed and replaced.
Выберете то, что вам нужно
Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
Remove the back panel of the external casing, leaving all internal components resting in the front panel.
Remove the black handle from the main external casing.
Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
Using the Flathead 3/32" screwdriver, remove two 22mm screws.
Firmly grasping the motor, dislodge the internal components from the frontal external casing.
Remove the switch from the wires.
Gently, pull and release the two wired connections.
