Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace the battery of the BlackBerry 7290.
  1. Apply pressure to the lock button on the back of the device. Slide the battery cover down towards the bottom of the device, revealing the battery compartment. Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. Locate groove along the right side of the battery compartment. Remove battery by prying between the battery and the groove. Remove battery by prying between the battery and the groove.
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
Заключение
2 участников успешно повторили данное руководство.
kmathew
Участник с: 17.10.2009
3 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 19-6, Maness Fall 2009 Участник Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,825
