Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide demonstrates how to remove and replace the LCD screen.
Запчасти
Детали не указаны.
  1. Remove the battery cover and battery before continuing.
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. Using your finger nail or a spudger, carefully pry up the back cover.
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. Lift off the back cover.
    • Lift off the back cover.
  4. Remove the two T6 screws.
    • Remove the two T6 screws.
  5. Remove the daughterboard. Remove the exposed vibration motor.
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. Unscrew the screw holding the back plate.
    • Unscrew the screw holding the back plate.
  7. Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force. Lift off front cover from metal plate.
    • Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
    • Lift off front cover from metal plate.
  8. Pry off the LCD screen with spudger at the two clips.
    • Pry off the LCD screen with spudger at the two clips.
  9. Remove the LCD screen and replace it with a new one. Careful not to rip the LCD ribbon.
    • Remove the LCD screen and replace it with a new one.
    • Careful not to rip the LCD ribbon.
Заключение
Neil Johnson
Участник с: 24.01.2010
12 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 14-44, Regan Winter 2010 Участник Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,531
