Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the six T6 Torx screws on the back of the phone.
Make sure to keep the screws somewhere that they will not get lost.
Using your finger nail or a spudger, carefully pry up the back cover.
Begin in one spot and slowly circle around the device as you pry up all of the back cover.
Remove the daughterboard.
Remove the exposed vibration motor.
Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
Lift off front cover from metal plate.
