Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replace your faulty motherboard with a new one.
Выберете то, что вам нужно
Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
Remove the battery by prying under it with your finger or the plastic opening tool.
Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
Using the prying tool, unattach this cable by levering under the connector
There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
After you remove the old motherboard, you can then replace it with a new one.
3 участников успешно повторили данное руководство.
