Fix Your Stuff
Right to Repair
Parts & Tools
Запчасти
Детали не указаны.
  1. Press down on the battery release button and slide the back cover up with your thumb.
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Pry from the top of the battery to pull it out.
    • Pry from the top of the battery to pull it out.
  3. Slide the metal sim card cover to the unlock position.
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Remove the two T5 Torx screws circled at the top of the phone.
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Remove the red cover at the bottom of the phone.
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Be careful not to damage the front cover's plastic clips while trying to separate it from the phone. Use a spudger to pry the front cover away from the side panels. Work the spudger around the entire phone until the front cover is free.
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Remove the keyboard.
    • Remove the keyboard.
  8. Use a spudger to pry off the plastic ring surrounding the trackball.
    • Use a spudger to pry off the plastic ring surrounding the trackball.
  9. Remove the trackball from the phone. Remove the trackball from the phone.
    • Remove the trackball from the phone.
Заключение
Еще один человек закончил это руководство.
Sean Willis
Участник с: 26.01.2012
229 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 10-32, Amido Winter 2012 Участник Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 3,522
