Введение
Remove the battery of the BlackBerry Curve 8520.
Инструменты
No tools required.
Запчасти
  1. Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. Locate the slit between the top of the battery and the casing.
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
Заключение
7 участников успешно повторили данное руководство.
Matt
Участник с: 07.04.2011
1 710 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 9-62, Walters Spring 2011 Member of Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 членов
Автор 5 руководств
Один комментарий
very clear instructions
mirandaseagrave - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 6
За 30 дней: 19
За всё время: 12,597
