Введение
Use this guide to replace the motherboard of your BlackBerry Curve 8520.
Запчасти
Никакие детали не требуются.
  1. Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. Locate the slit between the top of the battery and the casing.
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
    • Remove the two Torx T6 screws to the left and right of the battery.
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
      • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
Заключение
31 участников успешно повторили данное руководство.
Matt
Участник с: 07.04.2011
1 710 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 9-62, Walters Spring 2011 Member of Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 членов
Автор 5 руководств
Один комментарий
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 7
За 30 дней: 20
За всё время: 35,795
