Выберете то, что вам нужно
Use your fingers to pinch the battery at the grey semi-circles on the edges of the battery and remove it from the device.
From the mid-frame of the device, use a screwdriver to remove the six screws.
Set the screws aside once they've been removed.
Gently remove the mid-frame from the phone, exposing the motherboard.
This is the motherboard.
Gently pull back the plastic tabs that secure the motherboard to the case.
Slowly work your way around the case until the tabs are lifted and the motherboard is free.
Remove the motherboard.
Carefully detach the antenna from the two clips on the side of the motherboard.
In the same manner, disconnect the antenna from the motherboard.
Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
Gently remove the screen, taking care not to damage it by applying too much pressure.
Lift up the motherboard from the bottom edge to reveal the ribbon cables.
Carefully disconnect the two ribbon cables connecting the motherboard to the display.
3 участников успешно повторили данное руководство.
