Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
Gently pry the back the plastic tabs that secure the motherboard to the case.
Slowly work your way around the case until the tabs until the motherboard comes free.
Remove the motherboard.
Carefully detach the antenna from the two clips on the side of the motherboard.
Carefully disconnect the antenna from the motherboard.
Lift the up motherboard from the bottom edge to reveal to ribbon cables.
Carefully disconnect the two ribbon cables connecting the motherboard and display.
3 участников успешно повторили данное руководство.
