BlackBerry Pearl 8100 Logic Board Replacement
Выберете то, что вам нужно
  1. BlackBerry Pearl 8100 Logic Board Replacement, Battery: шаг 1, изображение 1 из 1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. BlackBerry Pearl 8100 Logic Board Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  3. BlackBerry Pearl 8100 Logic Board Replacement: шаг 4, изображение 1 из 2 BlackBerry Pearl 8100 Logic Board Replacement: шаг 4, изображение 2 из 2
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  4. BlackBerry Pearl 8100 Logic Board Replacement: шаг 5, изображение 1 из 1
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  5. BlackBerry Pearl 8100 Logic Board Replacement: шаг 6, изображение 1 из 1
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  6. BlackBerry Pearl 8100 Logic Board Replacement: шаг 7, изображение 1 из 2 BlackBerry Pearl 8100 Logic Board Replacement: шаг 7, изображение 2 из 2
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
  7. BlackBerry Pearl 8100 Logic Board Replacement: шаг 8, изображение 1 из 1
    • Separate the logic board from the front panel.
  8. BlackBerry Pearl 8100 Logic Board Replacement: шаг 9, изображение 1 из 2 BlackBerry Pearl 8100 Logic Board Replacement: шаг 9, изображение 2 из 2
    • Gently remove the keyboard from front casing. It should snap out of place.
  9. BlackBerry Pearl 8100 Logic Board Replacement, Screen: шаг 10, изображение 1 из 1
    • After removing the logic board, place spudger between the logic board and screen and remove the screen, sliding it slowly away.
  10. BlackBerry Pearl 8100 Logic Board Replacement, Logic Board: шаг 11, изображение 1 из 1
    • To place the screen on the new logic board, place the golden-colored filament in the slot above the screen’s position, similar to how the old one was placed. There are two pegs that fit into the logic board and secure it.
Заключение
3 участников успешно повторили данное руководство.
Robert Cronin
Участник с: 04/08/10
544 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 34-57, Forte Spring 2010 Участник Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 5,654
