Введение
If the buttons on your BlackBerry Tour 9630 are unresponsive or become difficult to push, then your keypad is probably damaged or dirty. Use these step-by-step instructions to replace your BlackBerry Tour 9630 keypad and get it working like new again!
Выберете то, что вам нужно
Position the phone so that the keyboard is facing down and the back is facing up.
Push the center silver button upwards to release the back cover.
Take the back cover off and set it to the side.
Grip the battery where the light grey half circles are located and pull up.
Set the removed battery to the side with the back cover.
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
Using an opening tool, pry the top plastic covering off. As shown in the second picture.
Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
