Введение
If your trackball is unresponsive or damaged, then you will need to replace it. Use these step-by-step instructions to replace your trackball on a Blackberry Tour 9630.
Выберете то, что вам нужно
Push up on the center silver button to release the back cover.
Remove the back cover.
Grip the battery where the light grey half circles are located and pull up on the battery.
Remove the battery.
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
Using the small plastic opening tool, pry up the pop ribbon cable from the motherboard.
Еще один человек закончил это руководство.
