Введение
Outline what you are going to teach someone how to do.
Запчасти
Никакие детали не требуются.
  1. Before beginning this installation, make sure phone is powered off .
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. Remove the battery from the phone.
    • Remove the battery from the phone.
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
    • Remove the back casing using the Plastic Opening Tool
      • Once the back casing is removed the top two buttons are likely to pop out.
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
      • Trackball will fall out once the casing is removed.
Заключение
Martha de Maria y Campos
Участник с: 12.04.2012
55 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 17-27, Amido Spring 2012 Member of Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 509
