Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the motherboard on your BlackBerry Z10.
Выберете то, что вам нужно
The rear panel pops off easily. Grab the opening at the bottom and work your way around.
There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw.
Disconnect the logic board connector near the top and left side.
Underneath the connector on the left side, there's two other connectors. Disconnect those.
Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
21 участников успешно повторили данное руководство.
2 Комментариев
For what is the second Screwdriver and what size is the right on?
