Blackberry 7105t battery contact Replacement
Выберете то, что вам нужно
  1. Blackberry 7105t battery contact Replacement, Blackberry 7105t Disassembly: шаг 1, изображение 1 из 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t battery contact Replacement: шаг 2, изображение 1 из 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t battery contact Replacement: шаг 3, изображение 1 из 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t battery contact Replacement: шаг 4, изображение 1 из 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t battery contact Replacement: шаг 5, изображение 1 из 3 Blackberry 7105t battery contact Replacement: шаг 5, изображение 2 из 3 Blackberry 7105t battery contact Replacement: шаг 5, изображение 3 из 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t battery contact Replacement: шаг 6, изображение 1 из 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t battery contact Replacement: шаг 7, изображение 1 из 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t battery contact Replacement, battery contact: шаг 8, изображение 1 из 1
    • With the speaker facing you, place your fingers on the gold battery connector.
    • Pull upwards and release the battery connector from the black body piece.
Заключение
kelogan
Участник с: 11/04/09
1 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-17, Regan Fall 2009 Участник Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 3,228
