Введение
For removing and replacing the Blackberry 7520 battery, follow this guide.
Инструменты
No tools required.
Запчасти
Никакие детали не требуются.
Turn the phone upside down.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
Добавить комментарий
Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
Финишная черта
Nathan
Участник с: 18.01.2010
31 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 5-7, Forte Winter 2010 Member of Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,429
