Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the phone upside down.
Push down on the black button on the back of the phone to slide the rear panel off.
The battery should be visible now.
Hold the BlackBerry in one hand face-up with the screen facing towards you.
Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
Use a pick or plastic opening tool to push the clips holding the rear away from you.
Repeat the process of unlatching the clips for the top section of the Blackberry.
Remove the motherboard.
Remove the indicated screw using the T6 Torx screwdriver.
Pull the metal plate away from the front panel of the cell phone.
Place the faceplate face-down and the interior of the phone face-up, as shown.
Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
Еще один человек закончил это руководство.
