Выберете то, что вам нужно
Press the cover release button on the bottom of your device. Lift and remove the back cover.
Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
Try to remove from left to right, using caution with the audio jack on the right side of the device.
Locate the volume toggle on the main frame of the phone.
Using the spudger, push the toggle in from the outside and remove.
Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
2 участников успешно повторили данное руководство.
