Выберете то, что вам нужно
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Orient the device so that the screen is facing you.
Using a spudger, remove the ear piece cover.
Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
5 участников успешно повторили данное руководство.
