Blackberry Bold 9650 Buzzer-Loundspeaker Replacement
Выберете то, что вам нужно
  1. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Battery: шаг 1, изображение 1 из 2 Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: шаг 2, изображение 1 из 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, SIM Card: шаг 3, изображение 1 из 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: шаг 4, изображение 1 из 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Back Chassis: шаг 5, изображение 1 из 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: шаг 6, изображение 1 из 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: шаг 7, изображение 1 из 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: шаг 8, изображение 1 из 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Buzzer-Loundspeaker: шаг 9, изображение 1 из 1
    • Use a plastic pry tool to remove the speaker.
    • Be careful removing removing the speaker as the plastic frame around the speaker is fragile.
Заключение
Еще один человек закончил это руководство.
Ryan
Участник с: 03/12/12
696 Репутация
Автор 11 руководств
Команда
Clemson, Team 2-5, Benson Spring 2012 Участник Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 3,976
