Введение
Use this guide if your Blackberry Bold 9650 faceplate is cracked, broken, or has any other form of damage that calls for a replacement. Faceplates are used to protect your phone by covering its exterior, so it is important that you replace it when it is no longer able to provide that protection. There are four prerequisite guides to follow leading up to this guide—all of which are included in these instructions.
Выберете то, что вам нужно
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Orient the device so that the screen is facing you.
Using a spudger, remove the ear piece cover.
Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
Using a pair of tweezers, lift and remove the following:
The two round connectors on the top of the mother board.
The flat connector in the lower corner of the mother board.
Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
Remove the faceplate by lifting the plate upward.
2 участников успешно повторили данное руководство.
