Blackberry Bold 9650 Faceplate Replacement
Выберете то, что вам нужно
  1. Blackberry Bold 9650 Faceplate Replacement, Battery: шаг 1, изображение 1 из 2 Blackberry Bold 9650 Faceplate Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Faceplate Replacement: шаг 2, изображение 1 из 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Faceplate Replacement, SIM Card: шаг 3, изображение 1 из 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Faceplate Replacement: шаг 4, изображение 1 из 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Faceplate Replacement, Back Chassis: шаг 5, изображение 1 из 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Faceplate Replacement: шаг 6, изображение 1 из 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Faceplate Replacement: шаг 7, изображение 1 из 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Faceplate Replacement: шаг 8, изображение 1 из 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Faceplate Replacement, Mother Board: шаг 9, изображение 1 из 1
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Faceplate Replacement: шаг 10, изображение 1 из 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Faceplate Replacement: шаг 11, изображение 1 из 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Faceplate Replacement: шаг 12, изображение 1 из 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Faceplate Replacement, Faceplate: шаг 13, изображение 1 из 2 Blackberry Bold 9650 Faceplate Replacement, Faceplate: шаг 13, изображение 2 из 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
Заключение
2 участников успешно повторили данное руководство.
Ryan
Участник с: 03/12/12
696 Репутация
Автор 11 руководств
Команда
Clemson, Team 2-5, Benson Spring 2012 Участник Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,385
