  1. Turn the device upside down. Using your finger, slide the silver cover release button towards the top of the device.
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Using your fingernails, lift the sides of the battery.
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Orient the device so the screen is facing the ground.
    • Orient the device so the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Gently pull out the SIM card.
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
    • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  6. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  7. Orient the device so that the screen is facing you.
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  8. Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
    • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  9. Remove the back chassis by gently pulling the chassis back and forth.
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  10. Orient the device so the screen is facing the ground and the top of phone is facing you.
    • Orient the device so the screen is facing the ground and the top of phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  11. Using your fingers, carefully lift and remove the mother board.
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  12. Using a pair of tweezers, remove the three ribbon connectors.
    • Using a pair of tweezers, remove the three ribbon connectors.
    • The ribbon cable connectors are delicate and easily damaged.
  13. Remove the mother board by lifting the board upward.
    • Remove the mother board by lifting the board upward.
  14. Using a pry tool, lift up on the four tabs located on the edges of the faceplate. Remove the faceplate by lifting the plate upward.
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  15. Lift the keypad out of the the front cover.
    • Lift the keypad out of the the front cover.
Заключение
3 участников успешно повторили данное руководство.
Ryan
Участник с: 12.03.2012
642 Репутация
Автор 11 руководств
Команда
Clemson, Team 2-5, Benson Spring 2012 Member of Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 членов
Автор 11 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 7,094
