Fix Your Stuff
Right to Repair
Parts & Tools
  1. Press down on the battery release button and slide the back cover up with your thumb.
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Pry from the top of the battery to pull it out.
    • Pry from the top of the battery to pull it out.
  3. Slide the metal sim card cover to the unlock position.
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Remove the two T5 Torx screws circled at the top of the phone.
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Remove the red cover at the bottom of the phone.
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Be careful not to damage the front cover's plastic clips while trying to separate it from the phone. Use a spudger to pry the front cover away from the side panels. Work the spudger around the entire phone until the front cover is free.
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Remove the keyboard.
    • Remove the keyboard.
  8. Remove the four T6 Torx screws located on the corners of the keyboard frame.
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. Now remove the left and right side panels. Now remove the left and right side panels.
    • Now remove the left and right side panels.
  10. Remove the keyboard frame. Be sure to unhook the screen housing from the motherboard before continuing.  Refer to the square indicated in the second picture. Now remove the screen housing.
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
Заключение
2 участников успешно повторили данное руководство.
Sean Willis
Участник с: 26.01.2012
229 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 10-32, Amido Winter 2012 Участник Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,529
