Введение
This guide was written to aid with Blackberry Curve screen replacement. Following the steps below should provide relatively simple means of achieving this goal.
Выберете то, что вам нужно
Locate the indent on the bottom of the back cover.
Use your fingernail to lift and remove the back cover.
Place the phone face up and use tweezers to securely grip and lift the screen upwards.
Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
Carefully pull the keyboard base up and away from the phone.
Disconnect the keyboard base from the phone completely.
Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
Use a plastic opening tool to find the crease below the screen.
Insert where shown and use the tool to unclip the two sides of screen from body.
From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
9 участников успешно повторили данное руководство.
