Введение
This Speaker Replacement guide was written to help consumers fix their device as easy as possible. The steps show the steps required to replace the speaker.
Выберете то, что вам нужно
Locate the indent on the bottom of the back cover.
Use your fingernail to lift and remove the back cover.
Place the phone face up and use tweezers to securely grip and lift the screen upwards.
Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
Carefully pull keyboard base up and away from phone.
Disconnect keyboard base from phone completely.
Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
Using a prying tool, find the crease below the screen.
Insert where shown and use the tool to unclip the two sides of screen from body.
From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
6 участников успешно повторили данное руководство.
