Введение
This replacement guide will walk you through replacing your SIM card. Listed tools are recommended; however, they are not required.
Запчасти
Никакие детали не требуются.
  1. First locate the two switches located on the lower backside of the phone.
    • First locate the two switches located on the lower backside of the phone.
    • Simultaneously, push the two switches forward causing the back to "pop" off.
    • The back cover should be fully detached from the phone.
  2. Once the cover has been removed, the battery should be immediately visible.
    • Once the cover has been removed, the battery should be immediately visible.
    • The battery is situated in the top half of the phone.
    • Using either your finger or the spudger/prying tool, remove the battery from the back of the device.
    • Your battery has a specific orientation to it. Make sure the bronze/gold colored leads are aligned with the bronze/gold colored strips on your battery before reassembling.
    • Once the battery has been removed, locate the SIM card. The SIM card is typically located in the center of the phone, secured by a metal tray.
    • Once you have located the SIM card, carefully remove it by sliding it upwards out of the metal tray. No tools are needed, just those fancy fingers.
    • Your SIM card has a specific orientation to it when it is replaced. Make sure the bronze/gold colored leads are aligned with the bronze/gold colored strips in the SIM card tray before reassembling.
Заключение
melanie lim
Участник с: 22.04.2014
607 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 9-16, Regan Spring 2014 Member of Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 7
За 30 дней: 13
За всё время: 846
