Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement
Выберете то, что вам нужно
  1. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Back Cover Removal: шаг 1, изображение 1 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Back Cover Removal: шаг 1, изображение 2 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Back Cover Removal: шаг 1, изображение 3 из 3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 2, изображение 1 из 1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
  3. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, SIM Card: шаг 3, изображение 1 из 1
    • Locate the SIM card once the battery has been removed. The SIM card is typically located in the center of the phone, and it is secured by a metal tray.
  4. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 4, изображение 1 из 1
    • Remove the SIM card carefully by sliding it upwards out of the metal tray. No tools are needed for this step.
    • Your SIM card has a specific orientation to follow when it is replaced. Make sure the gold colored leads are aligned with the gold colored strips in the SIM card tray before reassembling.
  5. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Back Speaker: шаг 5, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Back Speaker: шаг 5, изображение 2 из 2
    • Place the opening tool underneath the camera lens' protective plastic cover and pry them apart with gentle force.
    • Make sure the plastic cover has been fully removed by carefully lifting it away from the device with your fingers.
  6. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 6, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 6, изображение 2 из 2
    • Flip the device so that the touchscreen and Blackberry logo is facing you.
    • Place the opening tool underneath the front plastic cover located below the buttons with red and green phone symbols.
    • Lift and remove the plastic cover once the opening tool is in place. Make sure the plastic cover can be fully detached from the rest of the device.
  7. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 7, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 7, изображение 2 из 2
    • Remove the two bronze Torx T6 3 mm screws below the red and green phone symbols.
  8. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 8, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 8, изображение 2 из 2
    • Remove the four silver Torx T6 3 mm screws on the back of the device.
  9. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 9, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 9, изображение 2 из 2
    • Pry the opening tool into the slit between the two plastic sides of the device to separate the back panel from the front panel.
    • Slide the opening tool across the slit until you are left with two, separated front and back panels.
  10. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 10, изображение 1 из 1
    • Locate the silver speaker marked with numbers and letters on the back panel of the device.
  11. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 11, изображение 1 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 11, изображение 2 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 11, изображение 3 из 3
    • Place the opening tool underneath the silver speaker component.
    • Use the opening tool to lift the speaker off of the panel with light force.
    • Set the speaker aside once it has been fully removed.
    • When removing speakers, replacing or re-inserting them may result in looseness. This means that during re-assembly they may fall out or shift. An adhesive may be necessary to keep the speaker in place.
  12. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Motherboard: шаг 12, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Motherboard: шаг 12, изображение 2 из 2
    • Locate the red tabbed pin strip connected to the motherboard. The red tabbed pin strip is located on the right-hand side of the back of the phone.
    • Disconnect the red tabbed pin strip from the motherboard by inserting the opening tool under the side of the tab and gently pulling upwards toward you.
  13. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 13, изображение 1 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 13, изображение 2 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 13, изображение 3 из 3
    • Locate the yellow tabbed pin strip which is directly next to the original location of the red tabbed pin strip.
    • Disconnect the yellow tabbed pin strip from the motherboard using the same technique used to disconnect the red tabbed pin strip in the previous step.
  14. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 14, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 14, изображение 2 из 2
    • Disconnect the antenna cable located at the top right corner of the black panel using the opening tool.
    • Insert the opening tool underneath the side of the antenna connection, and gently pull upwards to disconnect the cable.
  15. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 15, изображение 1 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 15, изображение 2 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 15, изображение 3 из 3
    • Locate the second antenna connection toward the middle right area of the back panel. It is found in the corner where the red and yellow tabbed pin strips met.
    • Remove the antenna connection using the same method done in the previous, top antenna removal step.
    • Loosen the bottom metal cable grip (which pins down the cable) to separate the antenna from the motherboard entirely.
  16. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 16, изображение 1 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 16, изображение 2 из 3 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 16, изображение 3 из 3
    • Remove the entire motherboard now that all the components holding it down have been removed or disconnected.
    • Grip the top right edge of the motherboard with your fingers and remove it by pulling it out gently.
  17. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Screen Button: шаг 17, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Screen Button: шаг 17, изображение 2 из 2
    • Hold the middle panel and lift it away from the frame to separate the middle button panel from the screen and front frame.
    • Set the middle button panel aside after it has been fully separated from the screen.
  18. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement: шаг 18, изображение 1 из 1
    • On the underside of the middle panel is the screen button and accessory parts.
    • Replace the circled screen button (if needed) by replacing the entire middle panel.
    • Contact your plan provider or the phone manufacturer for details on obtaining a new panel.
  19. Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Volume Control and Convenience Key Buttons: шаг 19, изображение 1 из 2 Blackberry Storm 9530 Volume Control and Convenience Key Buttons Replacement, Volume Control and Convenience Key Buttons: шаг 19, изображение 2 из 2
    • Replace the volume control and convenience key buttons by replacing the entire middle panel.
Заключение
melanie lim
Участник с: 04/22/14
607 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 9-16, Regan Spring 2014 Участник Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 803
