Введение
A diffuser's fan and battery are common faults in a diffuser breaking down. The fan keeps the internals of the device, like the motherboard, from overheating. In this guide, we replace a fan from a Blossom Ultrasonic Essential Oil Diffuser ARM-510GY.
Before disassembling the diffuser, make sure there is no oil or water left in the diffuser and make sure the diffuser is unplugged.
Выберете то, что вам нужно
Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
Lift the ceramic top of the oil diffuser.
Then lift off the plastic top off the diffuser.
Gently unplug the cord from the circuit board.
Place the plastic lid somewhere safe on the a flat surface.
Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
Unplug the white connector.
There are four #M1 6 mm Phillips pan head screws holding down the fan.
Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
Gently lift the fan and place the fan someplace safe on the flat surface.
