Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Find the small slot on the bottom left corner of the back panel.
Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
When the back panel is loose enough, use your fingers to remove it completely.
With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
5 участников успешно повторили данное руководство.
If slot 1 is messed up can you use slot 2 for simcard and the phone still work
Margie White - Ответить
