Введение
Demonstrate the tear-down process and the removal of a broken speaker in the Bolide Technology Group Dual Alarm Clock, so that others looking to replace the speaker have a basis to build from.
Выберете то, что вам нужно
Remove the batteries on the bottom of the radio
Locate and remove the five screws on the bottom of the radio with a Philips Head Screwdriver.
Grab your nylon pry tool and wedge it between the outer case and the top of the radio. Slowly pry open the top and remove it.
Инструмент, используемый на этом этапе:Spudger$2.99
Using a black nylon spudger to carefully break the glue around the outside of the speaker so it can be dislodged.
Инструмент, используемый на этом этапе:Tweezers$4.99
Locate the speaker plug for the speaker you wish to remove and slightly tug on it until it becomes unplugged
After the speaker cord is removed, pull the speaker straight up and out of the radio.
Once the speaker is removed, the inside of the dual alarm clock should look identical to the photo shown.
Еще один человек закончил это руководство.
