Введение
If your Bonaok Q37 microphone battery is draining more rapidly than usual, consider replacing the battery so you don’t have to buy a brand new device.
Before you begin, make sure the device is powered off.
Выберете то, что вам нужно
Hold the handle with your right hand and unscrew towards you.
Once the cover is unscrewed completely, remove the handle cover.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to push the cover towards the left.
Lift up the cover to remove it from the microphone.
Push the battery towards the left and lift it up from the (+) side.
Remove the battery from the compartment.
Close the lid and seal back with the caution sticker.
Screw the handle back on by twisting it away from you.
Please charge the device completely before use.
4 Комментариев
What kind of battery?
Which type of battery? I looked on Amazon but can't find it. Must be age related problem, too old for new tech. 😊
Where can I buy replacement battery
NUMBER 18650 3.7volt lithium-ion rechargeable, available online everywhere BUT cannot ship with most carriers so delivery charge is expensive
