Введение
This guide will show you how to remove and replace the belts on your board. The rear motor is load with springs, so be carful and pay close attention to the steps when taking the board apart. If your belt is broken, you will need to buy a new one through Boosted. Happy fixing!
Выберете то, что вам нужно
Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
Compress the motor mount back towards the wheel.
While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
Rotate and pull counterclockwise until the wheel comes off the axle completely.
Remove the back washer from the axle.
Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
4 участников успешно повторили данное руководство.
