Bose Noise Cancelling Headphones 700 Ear Cushion Replacement
Выберете то, что вам нужно
  1. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: шаг 1, изображение 1 из 2 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: шаг 1, изображение 2 из 2
    • Optional: Remove the band around the ear cushions if you find it to be in the way while replacing the ear cushions.
  2. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: шаг 2, изображение 1 из 1
    • Take the old ear cushions off of the headphones using an iFixit opening tool.
    • Using the tool, go around the ear cushions from the inside or the outside of the cushions, and gently pry them off.
  3. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: шаг 3, изображение 1 из 3 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: шаг 3, изображение 2 из 3 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: шаг 3, изображение 3 из 3
    • Make sure that the ear cushion is for the correct side if that is specified for the ear cushions you are using.
    • Align the ear cushion with the slots in the correct places and press it onto the headphones.
  4. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: шаг 4, изображение 1 из 1
    • If you took the band off the headphones, put it back on.
    • Repeat steps 1-3 for the other side of the headphones.
Заключение
Based on the reviews of the various replacement ear cushions for the Bose Noise Canceling Headphones 700, the replacement ear cushions from the Bose website are the best if the noise-canceling ability of the headphones is a necessity. Otherwise, any other manufacturer for the ear cushions will work perfectly fine as long as they are made for these specific headphones.
Еще один человек закончил это руководство.
Anjana Chilukuri
Участник с: 07/05/23
139 Репутация
1 руководство автора
Команда
Austin Community College, Team 1-2, Meigs Summer 2023 Участник Austin Community College, Team 1-2, Meigs Summer 2023
AUSTINCC-MEIGS-SU23S1G2
1 член
Автор 2 руководств
Один комментарий
Anleitung ist sicher gut und zutreffend, zeigt aber leider keinen Bose 700 Kopfhörer.
Markus Scheuermann - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 32
За последние 30 дней: 114
За всё время: 1,471
